Print at Sep 28, 2026, 12:47:41 PM
Posted by MelbaToast at Sep 18, 2013, 7:27:41 PM
Re: Adjusting Memory Use
Hans, thanks for that information. I had time (out of panic mode of last night) to search the forum for issues. I realize this issue comes up.
This is my first "serious" project and I learned through it. I have a lot of objects and, like I told Puybaret in an email (just in case) I have them all grouped together.
My thinking is that there's simply too much stuff :/
My plan for now unless a real issue comes up is to work on adjoing rooms in a separate file so I can at least get a look through for rendering.
I also read that possibly grouping objects may be the issue, which will be a hassle to ungroup them for me, but if that works then I will do it as well.
I'm nearing the end of this one and starting another, but I've learned enough to not make some mistakes.
Thank you for your reply
