Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Proposal for solving problem with door and window thickness » » » » Post: Re: Proposal for solving problem with door and window thickness |
Print at Sep 29, 2026, 2:06:38 AM |
| Posted by Puybaret at Sep 24, 2013, 3:09:04 PM |
Re: Proposal for solving problem with door and window thickness The solution certainly requires to assemble composite objects with size/position constraints, something that doesn't exist in Sweet Home 3D. But your solution is largely incomplete, because in your seek to solve the "depth issue", you forgot that the user should be able to change the width and the height of the open door too. Then, I let you think about how many subparts it would require for a perfect solution! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 2:06:38 AM |
