Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Proposal for solving problem with door and window thickness » » » » Post: Re: Proposal for solving problem with door and window thickness |
Print at Sep 29, 2026, 10:06:38 AM |
| Posted by perdrix52 at Sep 25, 2013, 4:28:51 PM |
Re: Proposal for solving problem with door and window thickness Emanuale, I did think about that, as my proposal was that these attributes be the automatic behaviour - nothing to prevent manual override. I also suggested width and height overrides I realise that currently the furniture objects are not composite objects. But it should be a relatively simple thing (I suspect) as you already use composition when you place an multiple objects in a "house design". I wasn't searching for perfection, merely for something a bit nicer than today. To achieve close to that you would need to build up the door and frame in exactly the same way that a real door and frame are constructed. If you don't like it, then OK I can accept that. Dave |
Current timezone is GMT Sep 29, 2026, 10:06:38 AM |
