Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.2 » » » » Post: Re: Sweet Home 3D 4.2 |
Print at Sep 2, 2026, 10:40:02 AM |
| Posted by hansmex at Oct 10, 2013, 4:44:48 PM |
Re: Sweet Home 3D 4.2 The file demohouse displays correctly on my computer with Ubuntu 12.04. Only problem is the ceiling of level 2. Once you change the room on level 2, so that it has no ceiling, I can't see any problem with this file. Windows are normally tranparent, no overlapping blocks or other strange effects. The file cutouts shows: - two arches with wall segments at the top which are not closed at the bottom. So, the program makes the correct cutout and fills the space inside the arch. If you want the inside space open, then you will need to use an arch that is closed at the bottom. - two arches without wall segments. One is open at the bottom, the other is closed at the bottom. Both are correctly cut out. - two round windows with wall segments. These are correctly cut out. - one irregularly shaped window. This correctly cut out. Two of the arches have a problem: the wall partially fills in the cutout. I noticed that one of the arches with wall segments has no sides. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 2, 2026, 10:40:02 AM |
