Print at Oct 1, 2026, 2:17:19 AM
Posted by fildy at Oct 21, 2013, 6:49:39 PM
Re: Error on save - string index out of bounds
I managed to recreate the problem, as you say it was not the .mtl file, it was caused by a parameter in the .properties file. The furniture could be used in the plan, but an error occurred when selecting "save". To solve the problem I deleted all instances of the imported furniture, corrected the furniture library file re-imported it again.
When I created the furniture library (with items created from Blender) I copied the .properties file from a more complex model and edited them with a text editor, leaving the multiPartModel parameter set to "true" which caused the error on save.
Using the furniture editor would have avoided that problem but I was doing things manually as I had another problem earlier with the way another program handled the .mtl file.
Thanks for your help with this.
