Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.2 » » » » Post: Re: Sweet Home 3D 4.2 |
Print at Sep 29, 2026, 12:19:43 AM |
| Posted by hansmex at Oct 31, 2013, 5:04:16 AM |
Re: Sweet Home 3D 4.2 Emmanuel, Thank you for version 4.2. I´m afraid I found a problem using Ubuntu 12.04 and Oracle Java 7. The program starts normally and allows me to open files created with the beta 4.2. However, when I try to open files created with an earlier version (I tried files created with 4.1 and 4.0) there´s strange behaviour: 1 - When I open a file created in v4.1 or v4.0, the program seems to close. Strangely enough the tab that indicates a program is running stays active, and when I use System Monitor, the program is shown as active as well. However, there is no way to make the program display anything. I have to use End or KIll to terminate the program. 2 - When I first open a file created with a beta of v4.2, and then open a file created with an older version, the program instance showing the v4.2 file stays active and accessible, but the program instance of the v4.1 or v4.0 file doesn´t come up and is not accessible. Again, the only way to terminate those instances is to use the End or Kill command, which of course also ends the correctly running v4.2 instance of the program. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 12:19:43 AM |
