Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Curved Staircase » » » » Post: Re: Curved Staircase |
Print at Sep 29, 2026, 6:20:10 PM |
| Posted by okh at Nov 5, 2013, 1:42:08 PM |
Re: Curved Staircase I just realized I put semicircular where as I meant quart of a circle. How could I access quarter round walls and quarter round staircase? I see that one can do half circle wall in Sweet Home 3D. An arched wall you create by drawing a straight wall between two points, add Arc extent (lower right corner under Modify Walls, adjust positive/negative values until it fits).Curved staircases (objects with special cutouts in floors / walls) imported from other sources may need some extra work in the FurnitureLibraryEditor to work the way you want. The link below takes you to a couple of test models that should work (I included a 90deg curved staircase with various cutouts and walls). Copy and paste the staircase into your own model and change size, textures etc. SourceForge post, test cutouts ok ![]() |
Current timezone is GMT Sep 29, 2026, 6:20:10 PM |
