Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I customize the render settings » » » » Post: Re: Can I customize the render settings |
Print at Oct 2, 2026, 4:29:41 PM |
| Posted by sree.arun.kr at Nov 5, 2013, 5:16:31 PM |
Re: Can I customize the render settingsHans download this file which has default settings http://www.mediafire.com/?9vmlx54x3zv90nh Then copy, paste to the location "C:\Program Files\Sweet Home 3D\SweetHome3D.exe" or the location where the "SweetHome3D.exe" located. & Here is the description for the commands http://www.mediafire.com/?1hbx7495ki2iu7y Edit the values or delete the lines if you want to customize. Then save SweetHome3D.l4j.ini & start application "SweetHome3D.exe" Improper or null value makes application crash then delete SweetHome3D.l4j.ini from the directory To see Available Graphics memory Go to Win > Start > Run (or press Win-key+R),then type "DxDiag" & click display tab > Total memory= Memory Values must be a multiple of 32. Here is the file I uses to Exterior rendering http://www.mediafire.com/?76y5jukvyqthgkl Sorry for my bad .English. ![]() ---------------------------------------- ![]() |
Current timezone is GMT Oct 2, 2026, 4:29:41 PM |
