Print at Sep 1, 2026, 10:09:34 PM
Posted by okh at Nov 21, 2013, 3:12:45 PM
Re: Need a downlight (spotlight) with a bulb
How about adding a lightsource separately on the surface of the model you like? If you pay attention to the light power, size and placement/elevation, you should be able to get the desired effect. Then you can group the combination and copy.
PS Imported models will not have a light source included (unless I have missed something in the supported import formats). It is possible to add lightsource properties to any model, but much easier to follow the method outlined above.
