Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to import model of a cabinet with transparent glass panel? » » » » Post: Re: How to import model of a cabinet with transparent glass panel? |
Print at Sep 1, 2026, 8:50:57 PM |
| Posted by okh at Nov 25, 2013, 8:43:29 AM |
Re: How to import model of a cabinet with transparent glass panel? imported the created OBJ-File ... Your .mtl file appears to be imported without specifying transparency to your cabinet door. the glass panel in its door is just black ... How you deal with this in Art of Illusion, you may need to ask an Art of Illusion forum. However, you can quite simply edit the .mtl file and add transparency yourself so it works with SH3d.
Now, this will also allow you to find out where your transparency disappears. Also, looking at the file will tell you whether there is a reference to the texture. Sorry if this is on the technical side. I am afraid you will have to ask someone knowledgeable about Art of Illusion, to fix the original export. Good luck - for more info you can start with Wikipedia on .obj/mtl ok PS - your dropbox photo didn't show up |
Current timezone is GMT Sep 1, 2026, 8:50:57 PM |
