Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to import model of a cabinet with transparent glass panel? » » » » Post: Re: How to import model of a cabinet with transparent glass panel? |
Print at Sep 1, 2026, 8:50:42 PM |
| Posted by mito73 at Nov 25, 2013, 8:30:46 PM |
Re: How to import model of a cabinet with transparent glass panel? Thanks a lot, your hint solved my issue! After adding the d parameter to the proper material within the .mtl file my glass panel is transparent now after importing the cabinet into Sweet Home 3D. Regarding Art of Illusion: Since Transparency seems to be set in the material properties, I most likely will have to file a bug affecting the exporter there. ... in fact I just discovered there even exists already one - bad thing is, it is already 4 years old One question remains to me tough: I was expecting the .mtl file to keep information about the textures used for the model - in my cabinet example a wooden structure which I thought would be reflected in some sort of a texture image. This is not part of the .mtl file since it just looks like this (for the wooden texture called birch): newmtl Birch Kd 0.94838 0.90947 0.85077 Ks 0 0 0 Ka 0 0 0 illum 1 So how do I transfer this texture information to the Furniture Library Editor? Should there be an image containing the structure? As a Jpeg? With the same name than the material in the .mtl file? Thanks, Michael P.S.: For some reasons it seems that it is not possible to display pictures located on DropBox directly in the post (or I don't know the correct syntax) - so just follow this link ! |
Current timezone is GMT Sep 1, 2026, 8:50:42 PM |
