Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rendering on Windows Server 2008 Possible? » » » » Post: Re: Rendering on Windows Server 2008 Possible? |
Print at Sep 26, 2026, 1:30:07 AM |
| Posted by Puybaret at Nov 26, 2013, 9:29:40 PM |
Re: Rendering on Windows Server 2008 Possible? javac.exe did create ConsolePhotoGenerator.java I have some doubts about this. It should have created ConsolePhotoGenerator.class file. To simplify its use, remove the first line package com.eteks.sweethome3d.utilities; from the source code, and compile it again.The java command is followed by a class name, not a file, i.e. the basic command must be: java.exe ConsolePhotoGeneratorBut you also need to add to the class path all the libraries required to execute that class! If you host the ConsolePhotoGenerator.class file generated by javac in the subdirectory lib of Sweet Home 3D installation directory, then the command should look like this: java -cp lib;lib/SweetHome3D.jar;lib/Loader3DS1_2u.jar;lib/sunflow-0.07.3h.jar;lib/batik-svgpathparser-1.7.jar;lib/j3dcore.jar;lib/j3dutils.jar;lib/vecmath.jar ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 1:30:07 AM |
