Print at Sep 30, 2026, 11:42:03 AM
Posted by fxeon at Dec 3, 2013, 10:25:10 AM
Re: 3D view disappears in my saved model.
Think i found the solution ... i had a 0 thickness shower tray. removed it and now it's almost ok. I can't get the 3d view back to main window but the 3d view is working ok in a seperate window
i will post an abstract of log, if it helps ...
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
at com.eteks.sweethome3d.swing.HomeComponent3D$1$1.componentResized(Unknown Source)
at java.awt.AWTEventMulticaster.componentResized(AWTEventMulticaster.java:160)
at java.awt.Component.processComponentEvent(Component.java:6331)
at java.awt.Component.processEvent(Component.java:6285)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
