Print at Sep 26, 2026, 10:23:17 AM
Posted by hansmex at Dec 3, 2013, 2:23:45 PM
Re: How to... 'slice' the 3D view at a certain level
Arnaud,
Say your rooms are 270 cms high and your floors are 30 cms thick.
That makes a total floor height of 300 cms.
Double-click the Level tab and fill in these values.
Then draw walls that are 270 cms high. When you draw rooms, SH3D will add a ceiling/floor of 30 cms thick. This fills the gap between the floors, and closes the walls. Also, there will be no overlap, and you can select each wall in the correct level.
