Print at Sep 1, 2026, 4:10:14 PM
Posted by InteractiveMesh at Dec 12, 2013, 3:51:15 PM
Re: License for Gallery samples
I assume that in case of redistribution each used model in the home has to be assigned to its creator/author for giving the appropriate credit.
The Creative Commons Attribution 3.0 license requires:
"... keep intact all copyright notices ..."
"Attribution — You must give appropriate credit, provide a link to the license, and indicate if changes were made. You may do so in any reasonable manner, but not in any way that suggests the licensor endorses you or your use."
"You may not apply legal terms or technological measures that legally restrict others from doing anything the license permits."
In case of GNU GPL it is additionally required according to term 2a:
"You must cause the modified files to carry prominent notices stating that you changed the files and the date of any change."
The GNU GPL seems to be the appropriate license for a home-assembly-export. Additionally, each single model could be licensed under its original license if it would be extracted from the assembly.
I created an OBJ-export of SweetHome3DExample7.sh3d with SH3D 4.2 and converted it to X3D. Now I'm creating a model hierarchy based on Group nodes and modifying the models (aggregating shapes, generating normals, eleminating useless triangles, sharing appearances etc.). In parallel I try to identify the original author of each model for assigning the original license and credits. The goal is to provide an X3D test model for my coming JavaFX X3D importer.
August
