Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: AOI - colored objects? » » » » Post: Re: AOI - colored objects? |
Print at Sep 25, 2026, 11:05:54 PM |
| Posted by Theduck38 at Dec 15, 2013, 10:53:55 PM |
Re: AOI - colored objects? OK, I finally solved this... thanks to your hints !!! I created a .mtl file with your data inside, and added 'mtllib filename' at beginning of my .obj file. But the final trick is that the 50% transparent effect is visible on render only if when I position the window, I orient the 'black part' at the outside of the wall... I try to say it better : when you add a window, there's a thicker black line that can be either side of the wall. In my case, if this thicker black line is positioned inside the house, I get a totally transparent glass (seen from outside). If the black line is outside, I get the correct 50% transparency. Is it expected behaviour ? |
Current timezone is GMT Sep 25, 2026, 11:05:54 PM |
