Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.3 » » » » Post: Sweet Home 3D 4.3 |
Print at Oct 18, 2026, 7:12:09 PM |
| Posted by Puybaret at Dec 18, 2013, 4:29:42 PM |
Sweet Home 3D 4.3 Hi, Here's the first beta version of Sweet Home 3D 4.3 that you can test with Java Web Start. At the moment, it fixes only bugs among which: - a bug that prevented the 3D view to be displayed when it's saved as detached (see this thread), - a bug that didn't initialize staircase check box when imported model is modified (see this thread), - a bug that prevented to use % and # characters in dependencies of OBJ and DAE files (see this thread), - a bug that prevented to display correctly rooms that overlap at ground level (again), - a bug that selected the row under the cursor during a drag and drop from the catalog to the furniture table, - small bugs that were happening under Java 7 and Mac OS X. It should also better work in environments with more than one screen. As I can't easily test this under every system, I would be pleased to know if you still encounter some issues in such environments: don't hesitate to push the program, for example moving windows and dialogs showing 3D views from a screen to an other one, resizing them, etc… Thanks for your feedback and help ![]() [Note from developer: Sweet Home 3D 4.3 was released on January 14, 2014] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 18, 2026, 7:12:09 PM |
