Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Sweet Home 3d Viewer limits ? » » » » Post: Re: Sweet Home 3d Viewer limits ? |
Print at Sep 26, 2026, 11:06:04 AM |
| Posted by harvey186 at Jan 8, 2014, 11:21:59 AM |
Re: Sweet Home 3d Viewer limits ? Here my log from the terminal: Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/batik-svgpathparser-1.7.jar Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/Loader3DS1_2u.jar Missing Application-Name: manifest attribute for: http://www.reuthernet.de/Haus/lib/macosx/java3d.jar 3D [dev] 1.6.0-pre8-daily-experimental daily Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D$1$1.componentResized(Unknown Source) at java.awt.AWTEventMulticaster.componentResized(AWTEventMulticaster.java:160) at java.awt.Component.processComponentEvent(Component.java:6331) at java.awt.Component.processEvent(Component.java:6285) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:705) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) Java-Plug-in 10.45.2.18 JRE-Version verwenden 1.7.0_45-b18 Java HotSpot(TM) 64-Bit Server VM I don't know what "Missing Application-Name: manifest attribute for: " menas, but I think that's the reason, why I only get I white screen on my Mac |
Current timezone is GMT Sep 26, 2026, 11:06:04 AM |
