Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: proportional measurements to prepare self texture » » » » Post: Re: proportional measurements to prepare self texture |
Print at Sep 28, 2026, 11:57:00 AM |
| Posted by okh at Jan 11, 2014, 9:19:42 AM |
Re: proportional measurements to prepare self texture Depending on what you are used to, you can also use any simple drawing software to create your tiles in jpg, gif or png. Like Paint or whatever. If the same tile should cover the entire surface, Just draw a box with the same proportions as your tile adding an edge to represent the grout / mortar. When importing to SH3D, set the size of the tile (actually, you set the area that your image should cover). The image file itself could and should be kept relatively small, 64 pixels wide will do just fine for most tiles. Personally, I would prefer the GIMP (free) which is advanced software where you can add shades (blend/gradient tool), tile your design to make different shades to each tile, etc. However, very simple tools will get you a long way in designing tiles. ok |
Current timezone is GMT Sep 28, 2026, 11:57:00 AM |
