Print at Sep 30, 2026, 6:15:42 AM
Posted by Puybaret at Feb 24, 2014, 9:36:29 AM
Re: Problems with version 4.3 and Java 7 on Mac OS X 10.8
You should use the Jar executable version of Sweet Home 3D. To ensure that the max memory setting will be enough, run it with the following command in the Terminal:
java -Xmx2048m -jar /path/to/SweetHome3D-4.3.jar
To get the path of SweetHome3D-4.3.jar file, simply drag and drop the file from the finder to the Terminal window.
