Print at Sep 27, 2026, 7:03:57 PM
Posted by okh at Feb 28, 2014, 10:17:14 AM
Re: Help!! How can I use textures as stained glass?
.. png textures were made semi transparent... + ..transparency was specified in the .mtl file ...
I should add that finding the right balance between png transparency and mtl transparency is tricky. Especially with several transparent layers (curtains, window pane, lamp) - and even more so for evening rendering. Some experimenting is needed for the right effect to work for you (and I suspect that a different graphics card could produce different effects).
I added semi-transparent curtains to the model in the Sourceforge ticket (second post) (sorry, didn't have vertical blinds in stock smile ).
Good luck - and consider sharing, I guess vertical blinds are quite common many places.
