Print at Sep 28, 2026, 1:52:02 AM
Posted by hal9000 at Apr 3, 2014, 11:47:44 AM
Direct3D not working
Hello.
Not sure if this thread should go here or under the "installation" subforum. I just upgraded from SH3D 4.1 32b to 4.3 64b. I was using this SweetHome3D.l4j.ini:
-Xmx1024m
-Dj3d.rend=d3d
-Dsun.java2d.d3d=true
-Dsun.java2d.noddraw=false
-Dsun.java2d.ddoffscreen=true
-Dsun.java2d.ddscale=true
-Dcom.eteks.sweethome3d.deploymentInformation=DirectX
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=1
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=2
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=glossy
It worked fine with 4.1 32b, but when I try to open 4.3 64b with it all that I get is the splash screen and the application never starts.
If I remove (or comment with #) the line "-Dj3d.rend=d3d" then the application starts normally.
Could I do something to fix it?
Thanks.
If a long walk every day were healthy, mailmen would be immortal. tongue
