Print at Sep 25, 2026, 12:23:14 AM
Posted by szymi at Apr 3, 2014, 3:49:59 PM
Re: Change center-position in 3D aerial mode
Hello.
My apologies for posting on an old thread, but I found a simple way of changing the center of 3D view. I know there is now an "official" way of doing it described in the FAQ section, but changing the center by selection gets a little anoying when you want to move furniture around and at the same time to see your changes in aerial mode. My way of changing the center is to create a large room around the home (catching some area around it as well). The room may be square or rectangular, depending on what results you want to get. Make sure the floor is not visible. The center of the room is the center of your aerial view. You can move the room around to move the center. The room can be placed on an extra level below level 1 so that it does not get in your way when moving furniture around. Hope this tip will be useful to someone.
Szymon
