Print at Sep 29, 2026, 12:53:06 AM
Posted by hansmex at Apr 23, 2014, 10:52:41 AM
Re: AdvancedEditing.sh3p - Edit Room Points Menu is blank
Dean,
Not sure if this helps...
Edit Room Points only works on a room that has been defined before you use the plug-in. You cannot define a room using this plug-in. Also, you have to select the room for the plug-in to become active.
There's a tutorial available on the Documentation page.
