Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Open door bug. The Real Problem » » » » Post: Re: Open door bug. The Real Problem |
Print at Sep 30, 2026, 3:59:06 AM |
| Posted by Ferraro at Apr 25, 2014, 4:13:26 PM |
Re: Open door bug. The Real ProblemOkay, perhaps I may be wrong about the units, nevertheless all my open doors are working with no distortion whatsoever. Here is a quick solution... Insert one open door on a wall with magnetism on. Insert one open door not attached to a wall. Export all to .obj. Measure the depth of both open doors in your favorite .obj editor Calculate the percentage difference between the depth of each. Subtract the difference in percentage from your depth property. You might have to tweak the value by a tenth or so. Done, open doors are now compensated for with magnetism on. Mine all work. Sorry I referred to an obvious error in calculating geometry as a "bug." Good luck, hope this works for people. |
Current timezone is GMT Sep 30, 2026, 3:59:06 AM |
