Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D models specifications? » » » » Post: Re: 3D models specifications? |
Print at Oct 1, 2026, 11:28:14 PM |
| Posted by harbinger at May 1, 2014, 5:31:46 PM |
Re: 3D models specifications? That's what i tried -- i used 7zip to extract just the .properties file, which worked, and i made my edits (watching the syntax very carefully). When i tried to add it back into the file, i got am error message that read something like "Could not allocate memory." (I'm using Windows XP.) So i re-did the extension to .zip, extracted everything in the whole sh3f with 7Zip into a separate folder, replaced the properties file with the edited one, and re-zipped it. Then i changed the extension back to .sh3f. I tried opening it with the FLE and it took a minute, but it wouldn't load the file, obviously because the compression was wrong or something... Instead of having to edit this file directly, it would be better if we amped up the FLE features so we can add lights, etc, and edit the properties within a program. That way we don't have to be geeks that must know how to edit raw files. (I have a lot of lighting fixtures that i'd rather have lights installed in them; i'd like to avoid adding those invisible light sources.) |
Current timezone is GMT Oct 1, 2026, 11:28:14 PM |
