Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: No wall pattern when printing » » » » Post: Re: No wall pattern when printing |
Print at Sep 28, 2026, 4:13:16 PM |
| Posted by Puybaret at May 3, 2014, 11:21:29 AM |
Re: No wall pattern when printing I noticed some similar issues with the pattern applied to rooms and reported the bug to Oracle, but the pattern applied to walls seems to work correctly (I just tried again). But maybe you configured walls in a special way. Check for example if you don't have two walls superimposed at the same place using the contextual menu Select object. If that doesn't solve your problem, please send me your file, so I can check on my side. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 4:13:16 PM |
