Print at Oct 2, 2026, 2:45:05 PM
Posted by Ferraro at May 4, 2014, 3:39:52 AM
Re: 2 Wishes. Could be simple, not sure.
Awesome, so wish number 1. is a non-issue, I tried resizable# and it worked perfectly, thanks!
I am using Sweet Home to very quickly build 3d environments for a simple game engine were I can then run around the space in real time. So the extra faces can almost double my polygon count, reducing real time rendering performance. It usually becomes a problem on larger files. I have tried some clean-up optimizer plug-ins, but they still ruin a lot of faces and don't handle face collisions so well, leaving quite a bit of work to finally clean up. I do believe you have the very best, most efficient software for building 3d walls available; which is why I have adopted it for all my wall layout.
I really like your idea of simplifying wall geometry when one color is used (I always go with default wall white anyway) I would be willing to donate to the cause for reduced wall geometry. If any else agree, perhaps we can make it worth it? :)
Anyway, thanks for your response. I got all my non-scaleable objects set up.
