Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D models specifications? » » » » Post: Re: 3D models specifications? |
Print at Oct 2, 2026, 5:29:19 AM |
| Posted by harbinger at May 10, 2014, 9:31:12 PM |
Re: 3D models specifications? I was able to figure out how to get Windows to use its own archive methods to get into the .properties file. As okh mentioned, reset the .sh3d extension to .zip. (You'll get a warning but a low it anyway.) Then right-click on the file and choose "Open with..." and then "Windows Explorer". Windows will then treat it like a folder and make everything editable. You can then either open the .properties file of your choice there, or extract it to the desktop and open it with Notepad or some other text editor. After your edits, then save it back into the .zip folder, close it (it will be recompressed), and reset the extension to .sh3d. In okh's tutorial, he did casually note that it may not always work, and I hope someone can figure out how to make it work all the time (assuming of course the syntax is right). For my case, the edit I made on the one fixture (I added a light source to a lamp) didn't work, because when the FLE listed all the fixtures, it read everything but simply ignored that entry, not even displaying the icon. I checked the syntax carefully and I didn't see a mistake. |
Current timezone is GMT Oct 2, 2026, 5:29:19 AM |
