Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Invisible wall for a room » » » » Post: Re: Invisible wall for a room |
Print at Sep 30, 2026, 10:24:00 PM |
| Posted by okh at May 14, 2014, 9:31:54 AM |
Re: Invisible wall for a room Without knowing the details of your plan, how about: Drawing a room without walls? Drawing the walls and insert invisible frames to create the openings between columns? Using walls set to minimum height and thickness? You may also, of course, use short/thick walls as columns (useful for editing if they are to have same colour/texture as the nearby walls). But without the wall-enclosure you will not be able to auto-create the room. ok |
Current timezone is GMT Sep 30, 2026, 10:24:00 PM |
