Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.4 » » » » Post: Re: Sweet Home 3D 4.4 |
Print at Oct 2, 2026, 4:56:00 PM |
| Posted by Puybaret at May 16, 2014, 6:38:33 PM |
Re: Sweet Home 3D 4.4 Thanks for the details. About reflection/refraction values: at this moment reflection is set to 4 and refraction to 16; do you mean I should reduce refraction to 8 for better results? Unit conversion seems works fine but different converters have different fraction constant. Not sure I understood. Maybe you meant that each metric unit use a different count of decimals? It's on purpose, because values smaller that millimeters are not shown, leading to one decimal for centimeter unit and 3 decimals for meter unit.A button to clear cache(%AppData%\Roaming\eTeks\Sweet Home 3D\work) after complete project That won't happen because temporary files that aren't necessary anymore when program runs, should be deleted automatically. After an inquiry in source code, I discovered that some temporary files needed for SunFlow rendering weren't deleted once the rendering engine had finished its job, and I fixed this in the Beta 7 that I just released. All other files in the work subfolder can't be deleted before the program ends. The Beta 7 fixes also a bug that didn't show correctly rotated textures in SunFlow renderer (thanks Hans for reporting this issue). If you are planning to change render engine then please sunflow as plugin& yafaray instead. That's what I had in mind too, but as Yafaray isn't programmed in Java, it won't be easy.Sorry, other wishes won't happen in the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 4:56:00 PM |
