Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 4.4 » » » » Post: Re: Sweet Home 3D 4.4 |
Print at Oct 2, 2026, 4:56:03 PM |
| Posted by sree.arun.kr at May 27, 2014, 9:11:50 PM |
Re: Sweet Home 3D 4.4 So you mean that Ni shouldn't be used directly, Sorry it is a miss understand!, I mean that Ni shouldn't be derived correctly(Script Error & it is the bug). [Sorry once again for any spelling mistake or grammar mistake]. {I usually do open sh3d src.zip in eclipse & edit then export edited.java file as -java-jar file. Then using 7zip replaces proper class files in SweetHome3D.jar and start test rendering.} In this script line I understand that TransparencyAttributes transparencyAttributes = appearance.getTransparencyAttributes(); if (transparencyAttributes != null && transparencyAttributes.getTransparency() > 0 && !ignoreTransparency) { if (material instanceof OBJMaterial && ((OBJMaterial)material).isOpticalDensitySet()) { this.sunflow.parameter("eta", ((OBJMaterial)material).getOpticalDensity()); } else { // Use glass ETA as default this.sunflow.parameter("eta", 1.55f); } float transparency = 1 - transparencyAttributes.getTransparency(); photorender calls a value (Ni)as optical_density from objmaterial(*.mtl) and assigned to ETA and give it to sunflow for rendering. But I want to tell you that it fails to find the value from mtl file comes with .obj. Because assigned a value 2.5f as ETA for the 'if' condition if what ever the value of Ni. Then Render & the glass object render with optical density 2.5f. If I changed the glass material color/Texture it renders in optical density 1.55f. So I come to the conclusion that : optical density calling from (its default) *.mtl file or assign the value for eta failed. So sunflow render a black dot instead. I doubt that because of script error(spelling mistake /failed to maintain Ni value limitation in between 0.001-min to 10-max). !_________________________________________________ ![]() I am not propose 2.5f as eta.But the above image values are get from sunflow sample render secene file(glass01.sc) opened in notepad & rendered in sunflow gui. 2.5f takes 20% to 40% more time for rendering than 1.55f but give more realistic glass reflection. __________________________________________________ I found an invisible bug that when I import a furniture(most time *.3ds) & save it, then it produces a *.shed file consist of imported furniture as *.obj&*.mtl. But the bug is that when I export the imported furniture as *.obj then the file(*.obj&*.mtl) is totally different from than the saved file(the content of file/the method by which is used to export). This will not seen in geometry creation, but affect in glass type objects that have a curvy vine glass shape. Each time Import then export then again import & export each type of obj files are created & after some exports later the material glass loose its Ni value. I think the bug lies in OBJ exporter because If I import Obj files It saves same file but export then file creation method chagned & create a different file is being created, with no Ni parameter in mlt file some times. So please remove current Obj exporter(creation method) & use furniture library creator's/save as sh3d file's Obj saving algorithm instead ![]() ---------------------------------------- ![]() |
Current timezone is GMT Oct 2, 2026, 4:56:03 PM |
