Print at Sep 27, 2026, 6:16:43 AM
Posted by clanmills at May 31, 2014, 6:31:35 AM
sad   Re: Android Port of SweetHome3D
I've never used the Android SDK (which I believe is mostly Java). However from what Emmanuel has said about Swing and Java3D, I think porting SW3D to Android is not possible.
However, all is not lost. I'm working on "ToWebPlugin". This will make it easy to generate web galleries of images and floor plans and that will work with the browser on Android, iOS and the Desktop. ToWebPlugin
Although this doesn't enable you to render the SH3D model, it will enable you to share content on the web for viewing on mobile (and desktop) devices.
When I finish "ToWebPlugin", I have thought about a plugin to generate a 3D PDF. However I don't believe Adobe's Reader Mobile supports 3D at this time. http://www.3dcadworld.com/3d-pdf-viewing-goes-mobile/
