Print at Oct 2, 2026, 9:02:45 PM
Posted by Puybaret at Jun 11, 2014, 1:48:28 PM
Re: Sweet Home 3D 4.4
Is it possible to override the java6 -installer version with new JRE/JDK […] ?
Simply replace the content of the jre6 subfolder of Sweet Home 3D installation folder by the content of jre7 or jre8 folders found in C:\Program files\Java.
I am confused that in which line and page consist of light creation.
I just want to turn Off sky light,Keep turned On IBL light and render.
IBL is generated here and Sky light here.
Can you make more sharper/high resolution images in 2D window(Top)like the 3d(bottom) does.?
Sharper = higher resolution = more memory. It would be probably a good idea to add this in preferences. Be sure to post a feature request to avoid I forget it. Meanwhile you just have to set a value higher size than 128 for the canvas used to generate plan icons in PlanComponent class.
