Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sw 3D in Linux » » » » Post: Re: Sw 3D in Linux |
Print at Oct 3, 2026, 2:01:12 PM |
| Posted by Puybaret at Jun 15, 2014, 12:08:20 PM |
Re: Sw 3D in Linux You don't need to install Oracle Java with the installer version proposed on sweethome3d.com and SourceForge.net. Just double-click on the SweetHome3D file and it will run the program itself since there's no real installer program. When you double-click on SweetHome3D, the system might prompt you to Run the program in a terminal or not. If it fails, run it in a terminal, and report here the issue that may appear in the terminal. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 2:01:12 PM |
