Print at Oct 17, 2026, 9:47:01 AM
Posted by okh at Jun 16, 2014, 2:44:37 PM
Re: HELP !
Just for the completeness of the reply in case someone wonders (like I used to):
  • Walls have an Arc extent property that will curve a wall (+/- values).
  • The easiest way to draw a room within a curved wall, is first to draw the walls, and then double-click with the Room-tool. Then the room will follow the wall.
  • Rectangular windows and doors can be inserted in curved walls, but must be placed manually: adjusted depth so they penetrate the wall and exact angle to follow wall (use Alt to disable magnetism if you use mouse).
