Print at Oct 3, 2026, 8:57:50 PM
Posted by hansmex at Jul 16, 2014, 5:59:26 AM
Re: Invisible floor on upper level room.
Jeremy,
You didn't create floors in your plan, so it's logical that you can't see them.
Click the Floor button (to the right of the Walls button), then double-click in each room.
Problem solved!
Tip: read the Plug-in manual, install the AdvancedEdit plug-in and use the Connect walls function to connect the walls in the top-left corner of your design.
