Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two textures on one wall » » » » Post: Re: Two textures on one wall |
Print at Sep 2, 2026, 2:39:57 AM |
| Posted by okh at Jul 20, 2014, 10:37:50 AM |
Re: Two textures on one wall Method 3: use a lower wall (instead of a box) next to the higher wall - or just make it slightly thicker if you have stone on both sides. With this approach you need not worry about a new level, and it is easier to match the geometry of two walls than a wall and a box. Method 4: edit your (stone) texture adding the painted area on top, make sure proporsions are right, and import texture setting texture hight = wall height. Method 4 would be my preferred option as you can apply the same texture to many walls at the same time and it is easier to edit the sh3d walls later. ok |
Current timezone is GMT Sep 2, 2026, 2:39:57 AM |
