Print at Oct 7, 2026, 10:39:30 AM
Posted by okh at Jul 20, 2014, 10:56:40 AM
Re: swimming pool elevation
Depends how you design your pool and whether you use a model of a pool. Try using a negative level (Add Level, and edit it to the "bottom of the pool", say -220cm).
You can draw your pool as a room with walls on the negative (subterranean) level where the walls protrude above ground to form the edge of the pool.
