Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Import 3D format » » » » Post: Re: Import 3D format |
Print at Oct 3, 2026, 5:47:08 PM |
| Posted by Puybaret at Jul 24, 2014, 9:36:08 PM |
Re: Import 3D format Basically, you should decode the file format you want to import, then try to create Wall and Room instances that the imported data contains. Finally, add these objects to a new Home instance that you'll display at the screen by inspiring you from SweetHome3D main class source code. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 5:47:08 PM |
