Print at Oct 6, 2026, 7:32:29 AM
Posted by okh at Aug 3, 2014, 9:56:19 AM
Re: Merging 2 Sweet Home 3d Projects
If you open both files, you can copy one or several (selected) items from one project to the other, or did I misunderstand your question?
This at least is fairly easy for single level projects. If you want to copy walls and doors, you should probably take care to select all the windows and doors together with the wall, copy together. That way they stick together when you have pasted them into the other plan and can be placed easily together (your paste will be in the same position as they were in the original plan).
If you have several different levels and very many items, you need to put some thought into getting it right.
