Print at Oct 2, 2026, 1:22:09 PM
Posted by okh at Aug 18, 2014, 11:36:17 AM
Re: To create an opening in a work-top ?
Very nice work, and I think your 2D compromise is a good idea, but admit I think the 3D models look a lot nicer and more in line with the quality of your models.
..25 x 10 = 250 possible combinations.... - clearly not sustainable...
For my own use, I add the sink to the worktop when I make the model - but then I only consider a few sinks and only use the 60cm modules and 3cm worktop. Even if you can add texture later, it would make for too many combinations.
I also once tried using a separate level for the worktop (room = worktop where floor thickness = worktop thickness). And while that let me use the staircase SVG cutout for the sink so I could move it on the worktop, the solution was a bit awkward (and could not be integrated in a furniture library).
So I guess the solution proposed by Hansmex is the most appealing.
PS You should also note that there once were slight differences in the models sold in the different countries, but I think kitchen models are now all uniform with the most recent modular system.
