Print at Oct 2, 2026, 4:07:18 AM
Posted by dorin at Aug 21, 2014, 1:10:34 PM
Re: Making continues walls
Finally is relatively correct.
Now I understand Your problem related in initial post.
The program compute correct the dimensions wile consider the visible side of wall. The walls from 3~6 have an extra .10 thickness from walls you have draw before and after. It's very close to real world when you try to measure some walls.
To make continuous walls you need:
1. Install this great plugin;
2. Start drawing walls in one step (no mater the precise but the general aspect). That's mean you point and click (ONE CLICK) for every end of the wall.
3. The end of the last wall is preferably to be over the start point of the first wall. Finish drawing by double click, then press ESC.
4. In menu bar click on selection icon (the arrow).
5. Select LAST wall, press Shift + select FIRST wall to have both selected.
6. Wile selection go to Plan -> Connect walls .This option appear ONLY if the AdvacedEditing plugin is installed.
After few attempts I'm sure You got'it.
