Print at Sep 28, 2026, 2:02:28 PM
Posted by okh at Sep 11, 2014, 8:33:22 AM
Re: Is it possible to create glass wall?
Easiest - I find - is to use a transparent object. Import as window/door if you want it to run flush with the wall, or use it instead of a wall.
This model (posted in SourceForge 3D models 303) is what I use. Save the zip file and drag/drop into your model (check for door/window). Adjust size and change colour to your liking. If you need a frame for the glass wall, create a wall correct thickness and insert the transparent object into the wall.
