Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Making continues walls » » » » Post: Re: Making continues walls |
Print at Oct 1, 2026, 6:22:57 PM |
| Posted by Puybaret at Sep 16, 2014, 8:41:00 AM |
Re: Making continues walls Here's an other way that you might find easier: - Open a Terminal window - Drag and drop the icon of SweetHome3D program on Terminal window to copy its path - Type a space in the Terminal window - Drag and drop the icon of the .sh3p plug-in file on Terminal window to copy its path - Press <enter> in the Terminal window This should run a command like: /folder/SweetHome3D /anotherFolder/AdvancedEditing.sh3p[Edit: don't use the -open parameter] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 6:22:57 PM |
