Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Need a little help.! » » » » Post: Need a little help.! |
Print at Sep 28, 2026, 1:55:38 AM |
| Posted by sree.arun.kr at Sep 21, 2014, 4:10:44 PM |
Need a little help.! Hello Sir, Recently I faced a situation like I need to restore my windows to an old restore point, after it I re-installed java JRE 7 to JRE 8. Now on start up SH3D hanging my system like it uses real time priority and took 40 sec to 1 min for full loading.Also when I rotate 3d view it skips frames like a high end game runs in slower system.And also when the application closed the SH3D window disappears but it runs in background I need to end the process through task manager.(If does not drawn or changed anything it closes perfectly). Re installing java or increasing -Xmx1024m to -Xmx1280m does not solved. My system configuration is Windows 7 SP1 32bit,with 2GB RAM and 2GB GPU memory. ---------------------------------------- ![]() |
Current timezone is GMT Sep 28, 2026, 1:55:38 AM |
