Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Ceiling Anomily » » » » Post: Re: Ceiling Anomily |
Print at Sep 27, 2026, 8:58:22 AM |
| Posted by okh at Sep 26, 2014, 8:53:40 AM |
Re: Ceiling Anomily Looks to me as if there may be split walls / low walls that sometimes creates triangular ceilings attached to the floor. Although the ceiling works nicely most of the time, there are cases where ceilings are better disabled. So if the rooms are as square as they appear with wall same height, you may want to look for 'rogue walls' or mismatches between rooms and walls (create new rooms by double-clicking with the room tool inside _enclosed_ walls). Or just disable ceilings (and create a new level with a floor on top, if you wish). E.g. on a top level with sloped ceilings and different height walls, ceilings are usually better avoided (the logic of which floor areas and which walls should connect to the ceilings is not always obvious). ok |
Current timezone is GMT Sep 27, 2026, 8:58:22 AM |
