Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rooms and Ceilings » » » » Post: Re: Rooms and Ceilings |
Print at Sep 30, 2026, 2:20:38 PM |
| Posted by okh at Sep 26, 2014, 5:51:45 PM |
Re: Rooms and Ceilings Don't know whether the joints influences ceiling calculation. If you use the AdvancedEdit plugin to connect walls, make sure the direction of the walls are the same and that you select the walls in proper order. There are some oddities in the AdvancedEdit, but on second attempt it usually works - and could not live without... Judging by your pictures of the bay windows (?), I am not so sure I would use sloped ceilings calculated automatically. It is probably easier to rely on import/export/flip of the elements you want. ok |
Current timezone is GMT Sep 30, 2026, 2:20:38 PM |
