Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Fail to print to PDF in Ubuntu 14.04 » » » » Post: Re: Fail to print to PDF in Ubuntu 14.04 |
Print at Sep 29, 2026, 11:16:50 AM |
| Posted by Puybaret at Oct 14, 2014, 2:51:30 PM |
Re: Fail to print to PDF in Ubuntu 14.04 If setting a customized size paper with your own margins in page setup doesn't work, you could try to set the com.eteks.sweethome3d.swing.fixedPrintMargin property that was added in version 4.1. In SweetHome3D command line or your JAVA_ARGS var, simply add the option: ‑Dcom.eteks.sweethome3d.swing.fixedPrintMargin=0.2---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 11:16:50 AM |
