Print at Oct 3, 2026, 7:25:06 AM
Posted by okh at Oct 15, 2014, 9:47:28 AM
Re: Can I remove a section of wall?
..enter the whole wall, then erase parts?
Not to my knowledge - unless you insert an invisible window/door (must be placed/resized without magnetism - ALT key - if wall is curved - see thread 5366 ). But it is probably easier to edit wall elements manually with wall properties (start- and endpoints + arc extent).
Maybe you could use your existing plan as background image (select walls in the 2D window, copy, paste into a graphics editor, save as png and import as background image). If you draw on top of the background image, maybe it is easier?
Just a thought, but hard to tell without knowing more about your design. ok
